This machine is a 2015 Maverick Turbo XDS
So about 20% of the time it is physically difficult to select gearing that is far away like reverse - low or park. It feels like the selector is spring loaded.
When I am stuck up against something where the bike can’t move at all and I try to change gears it is also physically difficult to move the selector (almost like it’s spring loaded)
Almost every time I do change the position of the selector into anything park, neutral, high, low and reverse I don’t feel it engaging through the selector unless I lean forward and back so the vehicle rocks forward or back ever so slightly then I feel the gear engage through the selector.
This also happens when I drive into a trailer and put the machine in park. I have to move the wheels forward a quarter inch or back a quarter inch to hear the parking pin click.
If I don’t rock the vehicle forward and back and wait for the feeling (no audible noise) of the gear engaging it makes a terrible grinding noise if you try to drive it. It does this in R, H and L
It doesn’t try to move while idling. The primary spins while the secondary is stationary I don’t believe that is any problem.
My thought is maybe the gear selector cable needs adjusting or something in the gearbox needs adjusting?
Any advice would be greatly appreciated.
I have found tiny bits of metal in the transmission fluid as you would imagine from the grinding. Previous owner tried to tell me this was normal.
What should I look at replacing first?
