^^^ What he said ^^^Articbomb, he's a vendor on this site, has a fan override that is top quality and very easy to install, takes about 15 minutes.
when your running slow tight trails or under a load a lot its nice to be able to run the cooling fan to keep your engine cooler.Why would I need fan over ride- I'm uncertain if this mod is that interesting?
Do you still sell these? Could you make one for a 2007 outlander 650xt?Ours is plug n play with a sealed relay and spare acc plug.
Welcome from Tucson AZ. This is an 8 year old thread, ARCTICBOMB isn't even a vendor anymore. Check the Supporting Vendors section. Try UTV Inc. and others.Do you still sell these? Could you make one for a 2007 outlander 650xt?
Looks like a good switch set up. It probably won't help on the heating issue I was having going up long 30 minute hill at 35MPH as its probably caused from low coolant, but ordering the switch up because it will be helpful in the type of riding I plan to be doing. Thanks for the link.We have our Maverick plug and play fan over ride in stock. Check it out at the link below.
LINK: UTV INC CAN AN MAVERICK PLUG AND PLAY BACK LIT FAN OVER RIDE KIT
View attachment 270366![]()
No propblem let us know if you have any questions.Looks like a good switch set up. It probably won't help on the heating issue I was having going up long 30 minute hill at 35MPH as its probably caused from low coolant, but ordering the switch up because it will be helpful in the type of riding I plan to be doing. Thanks for the link.
