Thanks Tyler. Since the product is now available can you provide us a specific commentary on what your product does or doesn’t achieve relative to the below competitors information?
I want to purchase a reflash but I am rather confused now.
raise rev limit to 8500rpms
Low range limit 8500 RPM
No speed limit in low range
No torque limit on acceleration ( halfshaft saver removed)
Race start (Throttle opening while cranking allowed)
FAN activation at 167°F (75°C)
Engine and air temperature limp limit raised (limp home at 248°F (120°C) only)
no vehicle speed limit
100% throttle in low range, no need for sport low mod, & gear position on display reads correctly.
Allow gas & brake at the same time
Right now, I have two tunes, 8500RPM rev limit, or 9500RPM rev limit, otherwise the same.
I can change timing, fuel, and have different rev limit, if desired, for $50. more
The ecu can be reflashed back to stock if necessary.
Can I have this installed in Steamboat? Also, how will installing clutching, PC5, and a cat delete benefit my car with your reflash product?
