1 - 20 of 39 Posts
It's so fresh on the market it might be a bit to find someone who has one .
same manifold used by a few high performance shops
big improvement over oem manifold
you can find many 40-49mm turbos using the same manifold
different company's use different turbos
and the biggest I have seen is a 25-550
evo hustler kit says up to 600hp but the turbo is not described but says it uses a billet manifold
I have seen the evo Dynamite car run at 300+ whp
and I believe the 275 is WHP @$2700 with tune is a good deal
Reactions: warlock
Discussion Starter #4
Thanks for the reply.
From the number of looks a lot of people may be interested in the kit but the lack of response suggests it may not be past the prototype stage.
The web site lists the price as $4400.
I've done my share of development in the past and it was fun then but anything more is going to need to be proven in the hands of users.
44 is exhaust and clutch kit both are around $1k each plus most need a intake manifold
Just received my kit today. I’ll post up picks as we go
310 kit
Out with the old.
250348
Side by side
250366
Reactions: Abs151
looks similar, but the evo looks bigger
250367
AGENCY POWER turbo kit looks identical to the boondocker
the big turbo turbine exducer is about 40mm and oem is tiny
they are all 3 built by the same company Rotomaster. vivid, boondocker and Evo the difference is that the evo one was built more to their specs and also use 4 bar map sensors Vs stock and 3bar with vivid.
Which way are they plumbing the water lines into the turbo? I read where it’s important to make sure you don’t plumb a heat trap into the turbo for when it’s off.
here is a side by side view with the stage 6 sandblaster turbo vs the dynomite turbo.
Where did you read that?. here is the instructions for that part of the install if it helps.
251244
Thanks. I bought the Agency turbo. No instructions. Should have done my homework ahead of time. Was debating between vivid, evo and Whalen. I don’t want to be forced to run anything above 93.
Researching it and confirming with my mechanic. Here is the article I read. Thanks for info I’ll study it!
1 - 20 of 39 Posts
