I recently got my 21 rr tuned by evo. I bought the code shooter with they're shift tek kit. So first took for ever to get the purple spring secondary spring and they ended up sending a black with purple stripe and card saying this spring is exactly the same. Then I got my ecu back from them and when I tried to start and connect code shooter I got a check engine message and the ! Lite up and no start. Code shooter couldn't connect....so talked to evo and they said the didn't flash ecu and I gotta send it back....got it back, code shooter connected, downloaded 3r tune(I think because i have s21 phone), i adjusted clutches for the 91 3r tune, set crack pressure. Took it for a drive and reved up to 8400 rpms on the street with 32's and 7000ft elevation. That doesn't seem right for the tune calling for around 8k. So I thought maybe I didn't flash it right because in the instructions it says with s21 phone must re-energize dash by pressing start/stop button because with this phone it takes to long.....so after doing this..the flash process froze....tried to restart it and now get the check engine message again with ! Light on again and code shooter can't connect again like before when they couldn't flash it.....any one ever have this before...frustrated, can't talk to anyone at evo..hopeing someone else had similar experience....just about fed up at this point...
