1 - 2 of 2 Posts
just looking to see if anybody has put on 32 inch tires and then bought the clutch kit of lighter weights and primary spring from EVO did it work
Most clutch kits with the magnetic weights will be able to be adjusted for a tire size, if you’re not sure, or the manufacturer doesn’t list the tire/ terrain combo you ride, i would get an adjustable kit. Also if you swap tire sizes or terrain, an adjustable kit IMO would be the way to go. There are several vendors who make a version of it....
1 - 2 of 2 Posts
