lol? 1st post, cut and paste from evans web site and a link to china tools?Evans Waterless Coolants are the ONLY 100% waterless automotive engine coolant available on the market. All Evans Waterless Coolants are a chemical blend that results in more efficient cooling due to a higher boiling point. The increased boiling point of the coolant eliminates the occurance of boil over, cavitation, and detonation.
I could see it on applications such as heavy duty diesel engines that are built to withstand the added heat.....the fact that it is not corrosive and will not evaporate and does not expand much are good characteristics to have in a coolant. You could basically run it without a radiator cap and it would not boil over or expand enough to spew out of the bottle. But it is spendy...I've been playing with Evans since back in the 90's. They like to run engines hotter with higher stats and less fan on time. I don't agree with that and the coolant itself does not transfer heat as well as standard type antifreeze. I won't use it in any of my vehicles any more. The new ELC's are very high quality and last a long time. I just don't see the need for the added expense.
