1 - 7 of 7 Posts
About to install a 40" LED light bar on Maverick; I guess it is a 240W unit. I was told it draws about 20 AMPS; Is that about right? Well, if so, I am wondering if stock battery and magneto are powerful enough to run both such light bar and factory headlights together? I don't want to overtax the electrical system.
If it is an issue, what are the options available to run such setup?
Thank you much.
Benoit
Run it just fine had a 40 for a while no issues.
I've got a stereo, led halo's, 40" light bar, winch and power steering with no issues with the stock battery.
No problem. Ihave same bar. Just pay attention to the wire gauge on your cable. Should be 12 gauge minumum for that much current draw. Also make sure your relay or switch supports it as well.
Sent from my Lumia
1 - 7 of 7 Posts
