1 - 6 of 6 Posts
Hi all
Ive been strugling with my canam maverick xds 1000 R keeps on showing the engine light but no fault codes and says check engine when you start it . Ive read most of your post here ive replaced the plugs checked intake pipes . Checked the pipe from the intercooler to engine . Cleaned plugs . Checked al of the stuff ive read here but still shows the light . Anyone else has an idea what else can i do .
the CEL must be on to see active codes
using the light switch is not easy to read them
if there are no codes it usually says "no active codes"
Discussion Starter · #4 ·
Hi .
When i check the fault codes it says no active fault codes . I ve let it idle and checked the fault codes it just says no active faults even when i kill the engine and check it still says no active fault code
1 - 6 of 6 Posts
