Sorry guys this is going to be a little long winded.
I've been having issues starting my maverick. It will randomly act like the battery is dead and just click. The last two times it happened I hooked jumper cables up and before we hooked them to the other buggy it started right up, no problem. It's been getting a high idle randomly and other times it will stall on idle. Almost like there is to much pull on it, even though everything is turned off. So today I went to pull it out of the garage and it was dead. So I hooked up a trickle charger and immediately hit the start button and it fired with no trouble. I pulled it outside and let it idle while I was getting stuff ready to wash it and with in three minutes it stalled. I went over to restart it and the display and everything was off (no power), I then cycled the key a few times and still nothing. So I left the key on and went behind it to wiggle some wires thinking maybe i had a loose connection to the starter solenoid or a loose batter terminal, well everything was tight and it still wasn't on. I stood up to get the battery charger, made it a few steps away and heard the fuel pump cycle. I walked over hit the start button and it fired right up with no hesitation.
I have checked the battery terminals
The connection to the starter solenoid
The battery is good it's brand new and I was having this problem before I replaced it.
The starter was replaced under recall
I have an ssv radio, 40" baja lightbar, and interior lights all hooked up but none of them are drawing.
Any ideas what it could be?
