I had a local shop install the Eibach stage 3 kit and sway bars on my 2018 x3xrs turbo r, side by side. I'm running 14x10x30 STI tires with 12 lbs.
I just got back from the baja 1000 and to watch the race. The problem I'm having is that the rear is loose.
I run in the 4 wheel smart lock trail mode off road and switch to 2 wheel when I have to slab it the next section.
On the payment the rear end wants to come around and go into a slide even coasting, that is not normal and scary too.
The shock valuing are stock but the shrader valve cap was modified. Do I need to revalued the shocks or ?
