1 - 20 of 35 Posts
Thinking it would be cool if anyone who has had the opportunity to test their mavs on a dyno would post what numbers they were pulling with what mods. Give everyone some real world numbers on what mods are worth it all in one thread.
yup dyno's for sxs's is harder then cars alba pro shop hunterworks weller racing all dyno'd the maverick along with 10 other shops 72-74hp is average with clutch and exhaust people are seeing 82ish +
theres 2 different dyno machines and one will read about 10% lower then the other
a lot has to do with dynoing a sxs - tires wheels spin and locking the clutch to get real #'s
so yes its a lot harder then doing a car, obviously ur new at dynoing sxs's ! :)
2019 max R turbo
My Mav bone stock Dyno at 74 to 72 hp on Weller and KMS Performance Dyno. When Kelly at KMS Performance added the full STM clutch it got 82 hp just cause the stm clutch was so much more efficient at delivering the power to the wheels with less loss at the crank, it is truly the best performance mod that the Mav can get. The cat delete KMS performance installed added 2 more HP for a total dyno power of 85. The 60 mm TB and the welller intake didn't seem to add noticeable dyno power but the car accelerated 2 seconds faster over the same difference after the mod with the stm clutch was added and a great Pc5 fuel map
I stand corrected, I do realize there is a difference between dyno to dyno. But as far as a base line to start. & then mod a machine & use same dyno for results is as close to real world as your gonna get unless your back yard has a mx trac & your very familiar with it.
looks like the stm clutch alone is making 10hp
a few of the exhaust makers claim 8-11hp
when someone dyno'd a clutched maverick it made 82 from 72 , then someone dyno'd a exhaust only maverick and got 80 from 70 - then someone dyno'd a exhaust intake and clutch and got 85hp over 72 -
The clutch is the way to go, but very costly. The exhaust is a waste of money for the HP per dollar thing. I had a local shop build a cat delete for 175.00 and can only tell you that I could feel the difference, I guessed 2 to 3 HP so it looks like I was real close.
Discussion Starter · #12 ·
How much louder did the cat delete make it? I still like to try to have a conversation with my girl when we r riding.
You can't hardly tell a difference, just a bit louder. That is why I like the stock mufflers, there also built very well. I also added a fuel controller to lean out the top end, the factory has them to rich in the 11.6 to 11.8 range. It seems to run the best at 12.4 to 12.6 AFR
I agree, a good aftermarket clutch set up is the best bolt on mod you can do right now.
What fuel controller did you go with?
wonder if a fuel controller would void my warranty?
Depends on what the claim is for. They wouldn't have grounds to void your warranty for say a dead fan or something unrelated to the engine.
Reactions: KRIS
1 - 20 of 35 Posts
