1 - 4 of 4 Posts
its a well known issue for DWT, call them and they will send you new bolts that are larger. All you have to do is drill out the 6mm bolt holes to 8mm I believe. I did it to mine and no issues since.
Ok makes sense, did they charge you for the new hardware? Did you loc-tite the bolts when you put them back on? If not did you use Blue RTV?
no charge at all, no Loctite because the bolts are locking type. no silicone at all, in my opinion if you need silicone you have other issues.
1 - 4 of 4 Posts
