- Removable Internal stiffener helps bag hold its shape even when empty unlike all other dry bags
- Securely mounts with heavy duty quick release anodized aluminum cam buckles and nylon webbing
- Easily mounts to Motorcycle, UTV, ATV, PWC, and snowmobile
- Can be mounted across or along seat or tail section
- Electronically heat welded seams makes this bag 100% waterproof
- Air tight roll closure ensures no water enters the bag
- Made from waterproof and durable 24oz Tarpaulin PVC
- Coated outer material prevents slipping or marking
- Firm base panel helps support bag even when not supported by a rack
- Removable and adjustable carry handles can also be used to secure other items on top of your bag
- Strong D-rings allow more Survivor bags to be attached
- Hi-Visibility reflective accents on straps, front and sides of bag
- Quickly attaches to most factory tail racks or hard saddlebags
- Reflective compression straps easily adjust to the volume of content
- Includes an Exclusive Lifetime warranty
- Available in Black (SE-3000-BLK) and Yellow/Black (SE-3010-YEL)
- Main compartment measures: 20”L x 10”W x 12”H
- Holds 39.33 Liters
More info in our store-
[h=1]Dry Storage Duffle Bag[/h]
