Thanks... I suppose the bar is for the top mounts then and the hassle part comes when that mounting the fifth point belt.Use both lower mounting points same as factory belts do!
There are a couple threads showing how and where to mount the crotch belt. It makes it SOOOOO much more comfortable with the center belt because it holds the lap belt in the proper position so it cant ride up.Thanks... I suppose the bar is for the top mounts then and the hassle part comes when that mounting the fifth point belt.
Yea I posted pics on here somewhere but am too busy to go dig them up.......highly recommended though.There are a couple threads showing how and where to mount the crotch belt. It makes it SOOOOO much more comfortable with the center belt because it holds the lap belt in the proper position so it cant ride up.
welcome to the forum…..if you remove the interior panel and find the wire going to the seatbelt, just cut it and splice the 2 wires together.Anyone tell me how to get around the seatbelt electronics. How do i get around the safety switch that restricts the power if it is not latched when i install my new harness?
