1 - 10 of 10 Posts
Nice to see that the Trail has the same connector as the X3 for quickly wiring up a dome light.
Wired up the Wild Powersports kit pretty quickly.
Discussion Starter #7
@EFNFAST, it is already on. Provides power to what you plug it up to. So in my case it ran power to the switch that controls the dome light I installed.
So I just plugged the kit into that accessory plug, mounted the switch and mounted the dome light. Easy mod.
If you installed a winch and used the Can Am wiring harness kit for the winch then it is the extra plug from the power distribution block under the steering wheel. Just follow the wires and look for that white accessory connector that has no connection.
Skippy
1 - 10 of 10 Posts
