1 - 10 of 10 Posts
I recently added 4 speakers, 2 subwoofers,
2 amps, and a regular car battery and removed the stock battery.
Do you think this is okay?
What are the pros and cons to this?
Thank you!
That's a lead acid battery that can leak acid in a rollover, I would never have it in my X !
Reactions: TUNEZ5
Official Site Vendor
Here is one to consider because it has a bracket to hold the battery in.
253078
I went with a dual battery set up. The second battery has most of the accessories hooked to it and won't draw the primary battery down. The secondary battery only charges if the primary battery is charged. Piece of mind that the primary for starting should always be charged even if accessories are pulling more power than the Mav is producing.
Reactions: TUNEZ5
yup, two AGM batteries is the way to go and still have a good battery to start the car once you pollute the trails with your music. And those battery terminals are bad for corrosion, open air wire will corrode especially with the off gassing of your lead acid battery.
1 - 10 of 10 Posts
