I used the 3 packages labeled rear lower hub, rear middle hub, and rear lower hub and they were all the wrong size. Seems weird all 3 would be too long.
I used the 3 packages labeled rear lower hub, rear middle hub, and rear lower hub and they were all the wrong size. Seems weird all 3 would be too long.Did you use the correct bolt in the set? They are labeled, however it can be confusing. We will get you the right ones if the wrong bolt was packaged.
15673What was your order number?
The shoulder of the bolts are probably only 1/16" or so too long. There aren't enough threads to tighten everything down. I had to put the factory bolts back in. The entire front kit worked perfect though.How much too long?
Dempsey told me that there are washers supplied for the bolts in question. Did your kit have washers?The shoulder of the bolts are probably only 1/16" or so too long. There aren't enough threads to tighten everything down. I had to put the factory bolts back in. The entire front kit worked perfect though.
Your welcome.Haven't even picked them up yet but supposedly we're delivered today.
Thanks for processing my order so quickly
Let me know if any problems occur.They actually haven't been delivered yet, I must have misread the notification. Will respond once they get here
There was 2 washers per bolt. I'm guessing one for the bolt head side and one for the nut side? That how I had it.Dempsey told me that there are washers supplied for the bolts in question. Did your kit have washers?
Did that work?There was 2 washers per bolt. I'm guessing one for the bolt head side and one for the nut side? That how I had it.
noDid that work?
Not overall bolt length, but the shoulder of the bolt is too long. It's only on the three bolts going into the rear hubIf I can ask, what didn't work, washers or bolt length?
