so when I put heavier tires on my maverick ,blackwater evoulutions 28x11x14 28x9x14 I gained around 40 lbs over stock bighorns and rims. so I purchased a Dalton kit and black violet spring from hunterworks. I started out with the middle weight rivet weights and black violet spring.bottom end improved but it would top out at 67 mph .I talked to todd and he suggested going with empty arms and yellow black secondary spring .I did that and no change on the top end so I went with the heaviest weight rivets and back to black violet secondary spring .this combination was the best feeling down low and mid range but still no change on top end the best I would see was maybe 67 mph.the rpms stayed right at 8000 to 7950.a few weekends ago with new tires and no clutch work I saw 76 mph on blacktop but the low end was lacking.
