1 - 4 of 4 Posts
I just bought a set of 16" mea wheels and 30" tires and the first ride out I cut the front passenger side. It is cut on the bead, you cannot get a plug to it and I am pretty sure they are not going to be able to put an inside patch on it because of the location. I also tried slime and had no luck with it. My question is, what size inner tube do I buy for this size wheel and tire? The tires size is 30x10-16 but I cant find an inner tube to fit and. I would hate to buy a new tire with these being so new.. Please help.
Its better to buy a new one now so the tread height matches. Also sounds like you need better tires for you terrain.
16" with 30" tires don't leave a lot of sidewall, short stiff sidewalls don't flex well around rocks.
Quality tubes ain't cheap. You could look into tire balls or ghetto balls(kids rubber balls inside tires).
Just buy a new tire. What tire and on what rocks ?
I have a tire shop at tijuana bc and i can repair your tire and you will never notice...
I have a vulcanizer machine especial for those cuts ...were are you from?
1 - 4 of 4 Posts
