61 - 80 of 117 Posts
Are you goi g to have you set up done for next dune season?
interested to see what it costs you to piece meal this together vs buying a kit.....
In the long Run It's going to cost more, but if done right it should be a better system. I already have over 6000 in my turbo system but 2175 just in clutches doesn't help. I also bought the fuel monster (800) and bigger injectors and over sized pistons. The list goes on.
I only have around $2400 in mine including the cvtech not including labor charges. but that was over a year getting parts together at the best prices I could find
If I would have just started from scratch I would have saved a sht ton of money. Trying to fix someone elses kit was a big mistake.
UsedTurbo Teo4h 100$
5 foot of marine exhaust piping for charge pipe60$ Local shop
All the boost pipes ( 90deg 45 and straights ) 125$ Ebay
A bunch of 90 and 45 silicone for 2 inch piping 100$ Ebay
Used Intercooler from aerocharger 60$ Rzr forum
6 inch intercooler fan 60$ ebay
Local exhaust shop for 5 ft of 2 inch exhaust piping 30$
New 2 Deka 60 lb injectors with pigtail $75ebay
Used Pcv 200$ebay
LCD 200 200$ebay
Map sensor gm 3 bar 40$ebay
Kms map bypass 85$ Kms
Used Turboxs blowoff 75$ebay
Header wrap 50$autozone
Heat shield 50$ebay
Stainless oil3/4 return line. 50$ Ebay
Stainless oil line 25$local race shop
Cvtech 300$ebay
Epi red sec spring 20$ebay
Turbo flanges 50$ local fab shop
Cp 9to1 pistons 450$ mcx turbos
Gasket kit 100$ canam dealership
Rzr fuel pressure regulator 40$ Ebay
Turbo blanket 60$ebay
Total 2400$
Used Pcv 200$ebay
LCD 200 200$ebay
Heat shield 50$ebay
Cvtech 300$ebay
Total 2400$
Pictures???
That TE04h works good with only 60 lbs injectors?
Im guessing its a low boost build. I bet stock injectors are good for about 5lbs of boost.... Like I said im just guessing here....So maybe hes running like 7lbs. But with 9:1 pistons he could be boosting more then that...
I had to put a polaris Rzr 42 lb regulator to get it to idle like stock the stock injectors are like 30 or 32lbs good for 100 rwhp. And these are around 70 lbs with the factory fuel pressure
