1 - 20 of 127 Posts
CT RACING's front tie rods are in stock and ready to go! Replace those weak factory tie rods with a reliable part from Carolina Truggies.
They feature 1.25" solid billet 6061 aluminum rod with wrench flats.
We use only the best joints on the market which are JMX series FK 5/8 rod end. These joints use a fabric based teflon liner known as a PTFE liner. The inner joint housing is compressed to create a preload on the ball that will stay tight roughly 3 times longer then a standard injected teflon rod end which is standard in the industry.
The length is cut to have maximum thread engagement on the rod end while still keeping full adjustment.
Threads onto factory clevis/inner tie rod
Our misalignment spacers are 303 stainless steel so corrosion isn't an issue.
These are not a random spacer taken off the shelf thats made to work on the Maverick. Our joint spacers feature the exact mounting dimensions as the factory end to maintain the factory steering geometry.
These are 100% bolt on!
$195
I just ordered a set.
Discussion Starter · #6 ·
me likey, i need to talk it over with my wifey first, but ill prolly buy a set of these
Just let me know, they're going fast.
I got mine in.Thanks Alex. Nice pieces.
Just ordered mine!
Sent from my SCH-I605 using Tapatalk 2
Are these in stock?
I should have them by the end of July, you do not need to drill out the spindle.
So these are a direct bolt on, that way my stock ones can be used as an emergency backup?
1 - 20 of 127 Posts
