1 - 3 of 3 Posts
im at 2600 miles on my XC, all stock, never replaced the belt before. i will be replacing it now just to put a new belt in there, question is, is the one way bearing necessary to change?
any special tool i need to swap the one way bearing?
i alrady have the oem genuine belt
You need a tool to to pull your clutch off and with that many miles I would pull both clutches off and clean them up good and make sure your wear part's are all within spec and yes change your one way bearings I do every 1000 miles for good measure or at least grease them with the isoflex grease that is recommended..I assume you have never done this before so I highly recommend that you buy a service manual it will tell you exactly how to do it correctly
1 - 3 of 3 Posts
