This is my third post about what I perceive as a problem that I am not sure what to do about. My 17' Maverick Max 1000r DPS starts engaging the belt at 2450 RPMS and that seems high to me. Once it does engage the belt, it sounds like the rear diff is going to get torqued loose from the machine.
This isn't a muted clunk, this is a tooth rattling, feel in the seat of your pants, metallic chatter as the belt engages. I've been told just to go ride it. I find it somewhat unnerving to hear this thing engage. Hence my concerns.
I'm hoping for some substantial feedback on this. There has to be someone on this forum that can venture an educated guess as to what the actual the problem is. The bottom line is I don't want this machine to strand me somewhere.
What I have done to date:
1. Inspected belt, found it to be glazed
2. Cleaned the sheaves, checked the one way bearing and greased per the shop manual
3. Cleaned the sheaves again with brake cleaner and a green scrubbie
4. Replaced the belt with a new Hunterworks belt
4. Same problem
5. CV Axles were 3 years old, so decided to replace them (yes, they seated properly and yes they were OEM direct replacements)
6. Same Problem
7. Greased all U Joints (the front one under the engine was a bear to get to) they also feel tight when moving the drive shaft from side to side.
8. Same problem
9. Checked the rear diff for tightness, it was tight and torqued to spec.
10. The clutches appear to be original but I pulled them both.
I checked the rollers on the secondary (no flat spots) helix not worn, sheaves looked normal without damage.
The primary shows no wear on the cover plate bushing, Spider rollers were not worn but have some play side to side but very little. the bushings on the weights appear to ok as do the buttons.
What the heck else should I be looking at?
4. Same problem
6. Same Problem
8. Same problem
