it will climb a hill better then any other stock sxs u seen going up the hill
It depends on the type of hill your climbing whether or not your in low. Hard pack dirt hills where you can't get a run at it then you need low gear. Steep & slower hills I would use low but also get the sport low mode so you can keep your rpm's in the correct range. Large long hills like sand dunes I use only high gear.Does awesome. Make sure to keep it in low gear.
All 4 of my tires spin all the way up bud. And the 14's come with the qe so he should be fine. It climbs like a goat man, enjoy your new ride. Make sure u pick one up with power steering
the maverick will blow by a t4 on any hill ! what u talking about willisWRONG!!!!! my T4 crawls like a mofo with ALL 4 tires spinning ALL the time.
I don't care if u disagree. Go climb some hills with me before u tell me what my maverick is doing! It doesn't matter what wheel is in the air it will be doing what the other tire on the ground is doing. I have effortlessly climbed hills that I've seen wildcat owners stress over and hills that trex owners don't have the balls to try. Please don't talk about stuff u know nothing of. Only thing the maverick was missing was qe.i disagree. fully locked and the canam limited slip, spin to sorta lock is two different things. When the canam has a front tire in the air does it spin or freewheel?
not bashing the Mav but replying to Frank's comment.
Which costs $1000 to put on a 13? There has to be a better way if you need something like that.I don't care if u disagree. Go climb some hills with me before u tell me what my maverick is doing! It doesn't matter what wheel is in the air it will be doing what the other tire on the ground is doing. I have effortlessly climbed hills that I've seen wildcat owners stress over and hills that trex owners don't have the balls to try. Please don't talk about stuff u know nothing of. Only thing the maverick was missing was qe.
I have sport low - that I made myself instead of paying $200.... So that's why I always ride in low. Your avatar shows your rig on a dune, and that's not the type of hills i"m talking about. I ride in woods and rocks, and there's no way I'd go in high. That's just asking for a belt to be smoked.It depends on the type of hill your climbing whether or not your in low. Hard pack dirt hills where you can't get a run at it then you need low gear. Steep & slower hills I would use low but also get the sport low mode so you can keep your rpm's in the correct range. Large long hills like sand dunes I use only high gear.
Nope. Part of the deal from my dealer was that at the price I paid for my Maverick, the QE was provided and installed. When you go buy a new one, use that as a negotiating factor to throw in the QE.Which costs $1000 to put on a 13? There has to be a better way if you need something like that.
