CopperTown Concepts is proud to announce their latest product Spring Clean. This simple spring secures a microfiber towel at an arms reach to remove dust off your ride. Use the towel to clean your windshield, goggles, GPS screen, mirrors, even your plastic panels.
The Spring Clean comes with a microfiber towel, rubber tipped spring, billet mounting cup, and 1/4" hardware to mount it with. Simply drill a 1/4" hole in you dash, center console, overhead console even a blank switch cutout. All you need to do is bend the spring over and insert a screwdriver to hold the machine screw, then install the nyloc nut and washer on the back side and tighten.
Once your Spring Clean is installed all you need to do is pull gently on the spring and insert the included microfiber towel. Its that quick and easy you can do it one handed. The towel stays in place until you just pull on the towel for use then reinsert it into the Spring Clean when finished.
Look for your Spring Clean at you favorite offroad parts suppliers. MSRP will be set at $14.99. Unfortunately CopperTown Concepts WILL NOT be retailing at this time. All Spring Cleans will be sold wholesale to Dealers.
Dealer inquiries please PM or contact me at [email protected]
