Just tried that it's still onpull each one out fully and make sure its good, re install them firmly. see if it happens again
after u checked all fuses make sure the board is clean to , disconnect battery for 15 min then seeJust tried that it's still on
The code description is as follows:0 p1174 just through this
being that it's a V-twin, you have 2 of most everything so "swaptronics" is an option :wink:Trial and error is usually a good method in diagnosis issues like this.
exactly...Definitely a cheap way to diagnosis the problem instead of having the dealer rape you.
The mechanic at My dealer is an idiot so I'm better off fixing it myself. I'm going to tear into it tomorrow and see what's going on. With it being so muddy last night I hope it's just a corrosion issue.exactly...
Thanks!Good luck
I'm planning on it but I'm not sold that the light automatically shuts off and I don't want to be chasing ghostscheck it good a 1-2 mavericks have blown a motor from a cylinder running lean
