41 - 47 of 47 Posts
This is from 2018 Can-Am Models...
19/06/2018
SHARE
Re: Possible Fuel Tank Vent Obstruction May Cause Fuel Spray
Dear Can-Am® Owner,
BRP is conducting a safety recall on some of its 2018 Can-Am ATV models.
Our records show that you own a potentially affected vehicle.
What is the potential problem?
The fuel tank may build excessive pressure due to a blocked vent. This could cause fuel to spray on occupants or bystanders when opening the fuel cap, potentially causing injury. Additionally, if an ignition source was present, this could create a risk of fire, causing injury and/or damage to property.
Which models are involved?
Some model year 2018 Outlander™ and Renegade™ vehicles.
What will BRP do?
BRP will repair your vehicle free of charge. Corrective action involves reconfiguration of the fuel tank vent line. This should take less than an hour.
What should you do?
Contact your authorized BRP Can-Am ATV dealer and schedule an appointment to have the safety recall performed on your vehicle.
BRP recommends that the owners avoid using their vehicles until the corrective action is applied.
However, if the fuel cap must be opened, the following precautions must be adhered to:
  • Let the vehicle cool down for a 4-hour period.
  • Slowly open fuel cap ¼ to ½ turn maximum to release any remaining pressure.
  • Wait 1 full minute.
  • Open fuel cap.
  • Do not fill the fuel tank to more than ¾ of its full capacity.
Although your unit may have aftermarket modifications, you can still receive this service free of charge. The presence of these modifications, while the service is being completed, will not void any existing warranty or service contract.
Discussion Starter · #43 ·
19/06/2018
SHARE
Dear Can-Am® Owner,
What will BRP do?
What should you do?
  • Open fuel cap.
Thank you! I’ll send them that in the morning!
Discussion Starter · #44 ·
They swapped injectors to see if the code would follow. I guess the service manager took it out for an hour and couldn’t get it to pop.
41 - 47 of 47 Posts
