no need to even jack it up.....drive it to get it driving straight (disregard the wheel position). Slowly come to a stop and then loosen the outer locking nuts on both tie rods and adjust one side in and the other out in equally. Check wheel...repeat as needed. This is assuming you have the toe in/out set correctly to start with....That's the only adj.there is then,turning the rods way up by the boot?I'm on my way to buy a floor jack and start the fronts over.I'm starting to think I might have a bad tire so I'm going to rotate them.It likes to drift to the right if I let go of the steering wheel.
You should also check the ride height at all four corners, I had the same problem, my steering wheel was pulling to the right, I checked the toe, front and back, and it kept pulling to the right, the culprit was the front right side was lower than the rest, I cranked the preload on that coilover and problem solved, no more pulling.It's getting there now, I'll fine tune it later.I set zero toe in/out when I drove it earlier today.Still pulls to the right just a hair.I already toed in the right a hair and towed out the left a hair but it's getting too damn cold to check it.It was about 10 degrees out then, now it's about 5 above but going to get super cold for the next few days. The steering wheel seems to be getting back to centered on it's own,if not I'll pull it.When talking about a bent part, my right tire needed two fatter sized tire plugs to stop the leak, maybe something happened to the tire, it's on the same side.
You beat me to it. Tire pressure will definitely cause it as wellYou should also check the ride height at all four corners, I had the same problem, my steering wheel was pulling to the right, I checked the toe, front and back, and it kept pulling to the right, the culprit was the front right side was lower than the rest, I cranked the preload on that coilover and problem solved, no more pulling.
I also set the front to 1/8 toe in and 0 toe in the rear. Also check tire pressure.
I hope this helps.
Dang that's freking chilly. SD is a cool 65-ish today. :cool2:Think it's about there now but the temp. outside is -10 w/o windchill and going to get to around -25 F the next couple nights.Think I'll have to wait until this cold front moves on before I test it.My shop has heat in it so I'll probably take the skid plate off and clean it because I changed gear box,front and rear diffs. and motor oil and filter with it on.
you suck!Dang that's freking chilly. SD is a cool 65-ish today. :cool2:
yep, that will do it too....more than one way to skin a cat :crazy:I saw this earlier and forgot to post my suggestion.
What I do is grab a ratchet tie and double it up to the steering wheel. Then hook it to the frame on the seat, tighten it so it won't move but making sure it's centered. Loosen the steering, adjust everything center, toe in a 1/8th inch on each side (will help with high speed wobbles in the desert). Tighten it all back up and your good to go.
Northwestern North Dakota............this is a little colder than normal though, I hope it isn't the start of a very cold season.:crying:brrr....where do you live! I though it was cold here this morning at 16 degrees....
