Its interesting that it could move at all because normally a pinch bolt like that sits in a groove cut into the splined shaft and will keep the yoke from sliding as long as the bolt is installed, no matter how loose it is. My car isn't like this, there is no pinch bolt in front of the carrier bearing. I'm assuming that's a new design for later model cars or a max or something because my '17 2-seater has the pinch bolt at the forward end of that driveline where it engages the front diff. Either that or some knucklehead put the front driveline in backward. Assuming that yoke is set up correctly, it looks as if it isn't slid onto the splines far enough, ...like the pinch bolt has to come out, slide the yoke back about an inch, and reinstall the bolt. I'd think if it were on all the way you'd see the end of the splines through the open hole in the backside of the yoke.
