1 - 13 of 13 Posts
I used a 3 jaw puller to get mine off.
Yes, but more so because the one I used was a little to small and I was impatient when using it. If I would of taken my time I could of positioned it better to not dig into the plastics. I borrowed it from the local autoparts store.
Is the three jaw puller the way to go?
Only did it once,,, but worked perfectly for me. I believe I used the 6" puller of a 3/4/6" set that I own. Seemed to work just fine.
Official Site Vendor
Discussion Starter · #9 ·
I have a customer that cannot get the wheel off. His is really stuck on as is the one I have. I will pass this along and get the biggest 3 jaw puller in the tool box to pull mine. Thanks for the info!
It was a hell of a process to be honest, much tougher than other ones I've done, eventually I did get it off but definitely smoked the stock steering wheel
On my OG maverick I located a knuckle about 12 inches down the steering shaft, loosened that and pulled the wheel with that length of shaft, tapped it out in my vice. I would look down the shaft to see if you can pull it easily... I have never looked at the X3, it might be impossible, not sure.
1 - 13 of 13 Posts
