Canam just clicks once when starting again.
1.7K views 10 replies 9 participants last post by  OTTOSEAR
Check the connections to the starter solenoid with a wrench. Mine was 1/4 turn from fully tight once and did the same thing. Just a faint click in the dash when pressing the start button until the connection was tightened. If that does not fix it, check the ground wire to the frame on the passenger side behind the battery. It is probably something simple. These things usually are very reliable. Good luck!
