1 - 12 of 12 Posts
Hi I bought a powervision v3 from pwr tune. I accidentally ordered it for a 2018 x3 xmr but I needed one for a 2019 x3 xmr. Is there anyway I’m still able to use it?
Welcome from Tucson AZ. I suggest you ask pwr tune. They will give you the correct answer.
Ok I will thanks
It's not like members won't tell you that you can / can't, but get the answer from the manufacturer. IMO, you should be able to, I don't believe anything changed, but I'm not 100% sure.
Discussion Starter · #6 ·
Ok I emailed the a couple days ago and got no response yet so
No offense, but everybody emails. Call them. Places are busy, and the very last thing that is done is answering emails. If they are short staffed, even worse. Call and talk. Good luck.
Discussion Starter · #8 ·
Yea that’s what I’ve been wanting to do but I can’t today because there closed on weekends
X3 Max RS
The PV3 is the same for 2017-2020. Your tune will vary based on the PVInfo.txt file. Have you received a tune from them yet?
X3 Max RS
If it’s just the DynoJet tune you’re planning on using they are ALl downloadable from their website.
1 - 12 of 12 Posts
