I have a 2020 can am maverick x3 max and my check engine light came on code is p0340 anyone dealt with it?
Did you try a search? That code has been up before.
I didn’t really see a lot of info on itDid you try a search? That code has been up before.
Yeah, you’re right, I just checked.I didn’t really see a lot of info on it
Where is it locatedCrank shaft sensor. Do you have a fully charged battery? If so, check sensor wire connector and or wiring. If all good then replace the sensor.
I can’t open the image for some reasonSee attached
One last dumb question 😂 it’s the CPS right?
Yes. Down low.One last dumb question 😂 it’s the CPS right?
That statement is not true, you see you can replace the reluctor...when you do there's a flywheel attached to it...you cant replace the reluctor
it comes on the flywheel
Is the reluctor wheel right next to the cps sensor? Sorry not really familiar with part names yet of these machinesOne note is I think the 2020 is known for cracking reluctor wheel. So if it is Crank shaft position sensor related that may be the issue. Just something to be aware.
I used a small USB camera on one in my group last month and saw the damaged reluctor to diagnose it.
hey Tim I just checked my sensor and it’s full of bad pinched marked even had some cable showing! Got the sensor ordered! Hopefully this dose it! You recommend me still checking the wheel? Car has 96 hoursIt's what the Crank sensor uses to tell the computer what position the crank shaft is.
So it's right under the sensor.
All computer controlled vehicles use something similar.
If you have a small USB camera it can't hurt. If not I suspect the sensor is your trouble.hey Tim I just checked my sensor and it’s full of bad pinched marked even had some cable showing! Got the sensor ordered! Hopefully this dose it! You recommend me still checking the wheel? Car has 96 hours
