you may underestimate my stupidityWell that's a first, never seen nor understand why that would happen.
You will have to pull the turbo however it can be welded to be stronger than stock....Just make sure it doesn't mess up the area where the clip goes.
ended up throwing a bolt and nut on it. Rode it out in glamis and everything was just fine.Josh what did you finally do ?
Well there you go, glad it worked!ended up throwing a bolt and nut on it. Rode it out in glamis and everything was just fine.
thats what happens when you dont use a back up wrench on the arm. Puts torque on the welded pin.Well that's a first, never seen nor understand why that would happen.
Makes sensethats what happens when you dont use a back up wrench on the arm. Puts torque on the welded pin.
Well on my 2022 the damn nut has red loctite on it. I did the same thing. Silver solder the pin back on the arm.Trying to break loose the jam nut ending up breaking the pin that connects the actuating arm to the wastegate. Any ideas on how to fix this? Only thing i can think of is welding it together
Welcome from Tucson AZ. Heat / torch is needed to loosen red loctite.Well on my 2022 the damn nut has red loctite on it. I did the same thing. Silver solder the pin back on the arm.
I’m aware. My big mistake for sure. Just looked like paint (torque strike) not loctite. Also all the videos online just show you taking a 10mm wrench and loosening it.Welcome from Tucson AZ. Heat / torch is needed to loosen red loctite.
