1 - 13 of 13 Posts
Hi All,
I bought my maverick 2 weekends ago. It has a little over 200 miles on it.
I was out riding yesterday and when I went to hit the brakes, the pedal went to the floor!!!!! I almost crapped my pants. I was doing about 60!!!
I thought that maybe one of the brake lines broke off or something, but it's not missing any fluid.
Has this happened to any of you guys?
Thanks.
May have a defective master cylinder.
Reactions: AReed
Take your ride in soon and have them replace the master. There is a defective cup or blemish inside the cylinder if it only went to the floor once and then started working again. I would replace it if they don't. If it happened once it will probably happen again and at the worst time possible.
Brakes=force not to be reckoned with. The dealer will take your claim seriously.. or at least they should...:)
Sent from my SCH-I545 using Tapatalk
wow 1st brake problem like this
take to dealer they will fix u up asap
Loose axle nut allows the rotor to push the brake pads into the caliper - when you push on the brakes the pedal will goto the floor a few times until the caliper piston extend back out. Experianced it a few times - oh zhit!
So have the brakes been repaired and if so what was the problem?
1 - 13 of 13 Posts
