1 - 17 of 17 Posts
i have a brand new trail i went to
put a new winch mount on and bottom insert spun, i got it out but now im trying to find the insert and tool, the hex is 12mm any suggestions on where to get something suitable local or something to order appreciated
257488
I don't recall ever seeing a hex shaped nut-sert.
Just from the pic, maybe a nut tack welded ?
That's all I can think of.
I just seached and there are places that sell hex shaped nutcert. Tim
Discussion Starter · #4 ·
i find the hex ones online but most are 11mm or 13mm and this hole is 12mm was hoping for suggestions from people who gave done it appears to be common and this things only a week old trying to avoid drilling or welding the new frame and i feel
like the hex will hold stronger
2020 MavS Xrc
At least on MavT/MavS model variants, Can-Am provides numerous hexagonal holes punched into roll cage members for mounting accessories, such as for roof, rear view mirror and side view mirror attachment points. Those are nice in that the mating nutsert likewise has hexagonal body shape vs round cylindrical, which once swaged into position are much less likely to spin uselessly. Pics below show the one on each side as part of attaching Can-Am Sport mirrors. I didn't have a nutsert tool, so simply used a matching metric bolt, washer and nut (holding bolt head fixed while cranking down the nut until the backside of the nutsert swaged against inside of cage member). The OP should be able to obtain those hex nutserts from their dealer.
2020 MavS Xrc
If these are the specific inserts in question, threaded size is 8mm not 12mm (perhaps major diameter of the punched hexagonal hole). Looking at the MavT parts fiche for the frame, I don't see those 8mm inserts listed separately, since they're preinstalled in the frame member at the factory for all model variants. You might measure and compare that now exposed hex hole to the others I mentioned above. If same, seems likely Can-Am dealers keep them in stock for accessory installations. Also noting torque spec for those is just 142 +/- 18 inch-pounds. Did you over-torque during installation?
Discussion Starter · #7 ·
things brand new it spun taking it out but thanks for torque specs i can put it back correctly
2020 MavS Xrc
^^^ Agreed. Also, just now checked mirror e-instructions which indicates the roll cage member nutserts are M6. I still think best source of replacement M8 inserts would be a Can-Am dealer.
2020 MavS Xrc
Nice work inspector Clueso!
Agreed! Googling that p/n shows images including hexagonal backside of the nutsert barrel and flange which engages the mating hole. My own bubba method of using a metric bolt, washer and nut avoids need for a nutsert installation tool.
257517
257518
How did you manage to get the nutsert out? Mine spun even after applying heat to loosen the thread lock. Mine just sit and spin. I'm thinking I will need to drill out the bolt but you might have a better solution.
Discussion Starter · #16 ·
I removed the other bolts and pulled down on the skid plate at an angle, that held enough for bolt to come out then knocked rivnut into frame,
I will give that a rip. Do you think it’s possible to tighten and crush the rivserts after removing the bolt? Instead of knocking them out and replacing. That might be a challenge trying to spin a new bolt in.
1 - 17 of 17 Posts
