1 - 4 of 4 Posts
Spent all day designing and fabbing up doors. After several failed designs and wasted tube, finally came up with a workable design. These serve as side impact protection as well as suicide doors.
Still need to fab latchs and skins.
I can appreciate all the work that vendors go thru to build doors.
looks good !
Nice job. Yea fabrication is a lot of work, especially the Prototype. Curious why you did not have them open from the rear considering you had the option.
Discussion Starter · #4 ·
It was a consideration, but wanted the doors and frames to also serve as side protection. It was easier to double latch it at the front than the rear. The lower door frame will tie into the center cross member for strength.
1 - 4 of 4 Posts
