461 - 469 of 469 Posts
Looking for good tires for my X3 XDS. I will prefer made in the US. Right now I have the Tusk Terrabite 30x10x14. After around 1500 miles they start losing air pressure. One is losing air by the rubber 1/8 inch above the beadlock, we had the put a tube in it. When I remove the beadlock I saw Made in China. I am not happy, 5 tires good for the dump.
Asking out of curiosity I’ve looked through the form will a 3-5 inch spring lift be enough to clear 35-37s for deep trail mud riding?
NO. NO lift kits on an X3 for the umpteenth time! :mad:
X3 XRS - 2 seat - stock brakes
33x10x15 GBC Terramaster. 10 ply. 41.1 lbs. diameter measures close to 32" at 18 psi
1,200 miles central & east AZ+ Johnson valley with a nail in 1 of them and still going. I think they will go 1,400 miles. B-side out (hard terrain) in sand will push in the corner. Car brakes ok. Good on graded. Great on rocks. Tough tire.
35 x 9.5 x15- System 3 - RT320 - 8 ply- 43 lbs - has anyone tested it?
Contact patch suffers at a 9.5"? Steel belt or what is it?
Weight to tire diameter is attractive. 43 lbs at 35". Should roll over square edge better.
My only fear is the added wear on bearings, brakes, joints, and effect on shock rebound.
Both run about $200 /tire.
Experience anyone?
Hi guys! i changed from libertys 32" to big km3 32" in my x3 xrc rr. whoever goes through the same path, you will never look back. I love them, it is an incredible tire in all aspects they are simply better. Liberty is not a bad tire but it has nothing to do against km3. MY OPINION
258635
258634
258633
258631
Maverick x3 turbo max
I have 32x10R14 kantai mongrels mounted on 14x9 and 14x10 hiper sidewinder wheels. Each wheel and tire weigh in at 49 lbs. no rubbing or clearance Issues. 200 miles on this setup and so far so good.
258736
Just did my first ride on a new set of 33” System3 R320s. I am pretty impressed with them so far. The extra ground clearance is killer. Im right at 17” now on my DS. You can see how tall they are vs my old 32”(31” measured) MRTs. The R320s are a true to size tire and measure every bit of 33”
