1 - 8 of 8 Posts
Hickory, NC
I've seen an inline controller, only problem is you would have to route the line into the cab and back out again for adjustability. If you just want to limit front or rear, try searching drift forums, they might have what you need
If you are driving in 4 wheel drive, the brake bias adjuster will not make a difference. As far as I know, there isn't a center diff in these things, so the front and rear are locked together...
Sent from my SCH-I535 using Tapatalk
1 - 8 of 8 Posts
