here's some pics of stock 14inch wheels with 32" BFG's I was able to use the stock beadlock bolts with no problem.
Those look great. Stock wheels may be more robust and far as bead size. I think the issue is with the raceline wheels, also maybe because mine are 15 inch. More than half an inch bead and with these wheels you need spacers. Otherwise bolts are leaning and the bead ring is canting inward...here's some pics of stock 14inch wheels with 32" BFG's I was able to use the stock beadlock bolts with no problem.
Mine are 15" and weigh 43 pounds eachHow much does the 32x14 tire weigh?
Did you happen to weigh these at all?here's some pics of stock 14inch wheels with 32" BFG's I was able to use the stock beadlock bolts with no problem.
43 poundsDid you happen to weigh these at all?
You're probably over thinking it. The combined weight difference between a 14" wheel combo and 15" is most likely pretty close to a wash. One has more wheel and less tire, the other the opposite.Trying to find out how much the 14x32’s are. I was thinking of the weight difference between the 30 inch big horns on stock 14’s to these on the stock 14’s.
Probably way over thinking the 14 to 15 inch aluminum wheel vs is 1 inch of rubber or wheel heavier. I really like the get up and go I have (and the fact I’m still spanking my buddy in his 2020 rr)
Did you torque once or did you make sure to go around several times?So went riding over at north glamis hot springs. the trails there where so bad that I was just waiting for my car to fall apart. So wash boarded out it wasn't even fun. End of day one noticed that i was missing a bead lock bolt. Hmmm, okay. I know I torqued all of them to spec. Day 2 noticed 2 more fell out so now 3 in a row on one wheel front. Now I'm looking closely and see that they sheared off and the threads where still in there. What would cause them to shear off if torqued to 15 pounds? No marks on the wheel so I don;t think I hit anything. I am running the BFG'S ko3
Why not use some blue loctite to be safe?Keep going around until they stop turning and just click the torque wrench, slways takes me 4-5 rounds per wheel
