Check out the latest product from Bent Metal Off-Road. Everybody hates the doors on the X3’s that close by themselves. These solve that problem! The door assist kit uses a couple nice bracket and a hydraulic ram to assist the door. Helps stop breaking of the factory door straps while also holding the doors open for convenience when getting in/out of the vehicle and while working on it. Install takes about 10 minutes and requires a 13mm socket and wrench and a 5/32 Allen wrench. They also have two holes in the rear bracket that allows you to increase or decrease the rams pressure on the door depending on how much assist you want/need. $75
