1 - 17 of 17 Posts
2019 max R turbo
Please put me on the list cause I'm not in a big hurry to pick my up from the dealer til I can get the ECU unlocked.
2019 max R turbo
Get rid any and all torque limiting functions, axle saver, higher RPM limit, full power, and I would love to remove all those nasty limp mode features cause I monitor my temp, oil pressure.. through my gauges and don't need sensors turning my vehicle into a 1500 lb turtle...
Oh yeah, you can count on that!!! We are already working on the ECU and investigating what we can unlock for power, get rid of the axle saver function, and fix the drive by wire throttle delay.
Sweet!!!
Try to make sport mode work in low range please. There is an electrical mod to fix it, but you either have to buy some resistors and cut a wire, then wire them in along with a switch, or spend $195 on a wire harness. I'd rather have a programmer do it for me if I can.
Discussion Starter · #12 ·
Thanks for the tip. We'll look into making it happen!
Any progress on the ECU reflash?
7 months since we heard from Chris...I'd say they are having just as much trouble cracking the Mav ECU as they did trying to crack the Commanders ECU. Just a guess...........
That's possible but it maybe they just moved on to something else. And now he may be getting ready for the new Rzr.
I sent him a PM, so hopefully we will at least get an answer
1 - 17 of 17 Posts
