Belt question
15K views 20 replies 11 participants last post by  Greystone
I smelled some burning rubber on my last ride so I decided to do a belt change today. The belt has never been changed before. When I took the cover off, you can see that the belt markings are upside down. The belt is spinning the opposite direction as the indicated arrows. Is this correct or did the factory put it on backwards?
#3 ·
It doesnt matter first time use. Just maintain the direction after 1st use.
#13 ·
It really was good to do a dry run in the garage. Now I have all the proper tools to make this job much easier for me if I had to do it on the trail. I am use a small 1/4 inch ratchet with socket for the 4 bolts on the bottom. If Can AM had made a access panel on the skid plate that could be removed with 2 bolts, it would have been ideal to make the job a piece of cake. I also got a bunch of new clips as some got destroyed while taking the covers off. Will break in the belt easy over the next 30 or so miles
#21 ·
I have a Max and getting to the belt isn't all that tough as long as you've got plenty of patience a double jointed wrist for those bottom torx screws a bunch new plastic rivets and those other plastic gadgets under the rivets that offer break, have plenty of various tools on board to remove the seat, Side paneling, plastic floor, some new rubber elbows for the outer clutch cover cooling duct tubes ( they will tear and or fall apart easily especially if a few years old) etc, oh yeah and the new belt and spreader tool, LOL.
#20 ·
The annoying part with the max is removing the rear seat and floor boards. After that the process is similar to the 2 seater. But I will have to look at the 2016 quick access setup.
