This post will concentrate on sound. Sound you say? Yes, the sound from your intercom, radio, and whatever else you listen to like music or turn by turn directions, etc. One of the most overlooked parts of your high dollar install is the sound you actually hear (or don’t) from the setup.
Many choose some type of headset, which is great. They all have some type of passive outside noise attenuation and the speaker quality isn’t too bad for almost everyone with the exception of true audiophiles who are never satisfied with the quality of the sound. LOL. The mics are of decent quality and are very reliable. If not wearing a helmet is your choice, these headsets fit the bill nicely. Over the head or behind the head types are user preference, and I am partial to the behind the head style, especially if you wear a hat while driving.
But what if you wear a helmet? This is where I will suggest some things to make the experience better. The big guys (PCI,Rugged, etc) all have helmet kits. Some call them “enhanced or alpha bass” whatever. I dare say this is marketing hype. Why? All of these speakers will get the sound to your ears but the sound your ears perceive will always be sub-standard. Why? You always have to contend with the background noise from wind or the car itself. SO, we turn up the volume to an appropriate level for the conditions we ride in to overcome that noise. Is there a better option? Absolutely! It’s called ear transducers, which is just the technical name for ear buds. If you were to look closely at all forms of racing, like NASCAR, IMSA, etc, you will see the drivers put in their custom molded earbuds first, then the fire retardant hood, and then the helmet. Once the helmet is on they connect the earbuds to the helmet jack. Then they connect the helmet cord to their vehicle. Having a custom set is the gold standard, but can be a hassle and is pricey. In order to get these, a visit to the audiologist is mandatory. Sure, you can get a DIY kit and try but it never works out as good as when a professional makes the molds. No sense wasting time and money with the risk of poor performance when the professional will guarantee a perfect fit or they will do it again at no charge. Then the molds get sent to your choice of manufacturers to have them custom made for you. All this takes time and there are so many choices of transducers it can be rather confusing. Not for me, thanks.
So, what are the alternatives? A quality set of ear transducers that have some sort of foam tips that seal in your ear and are comfortable enough to wear all day. Your choice should take into account that the tips should be available in any size to match the user’s ear for best sealing and comfort, be easily replaced, and are easy to procure. They should be constructed of quality materials (especially the cords) and most of all, sound good in your ear. There are all kinds of these offerings out there but I will concentrate on the best one I’ve found. Let me first say that I am in no way affiliated with the company and receive absolutely no compensation for promoting their products. What I will say is that I have used their products in various applications from aviation to tactical and off-road. They have never disappointed.
Before I reveal the product, let me make a few comments about why I believe this is a better alternative to helmet speakers. First, when trying to block out the background noise, you have to raise the volume, sometimes higher than it should be, which can cause distortion in the ear. Distortion makes the conversation or transmission hard to decipher. It makes the music less pleasant to listen to when the frequencies are all jumbled together. By using these earbuds, the frequencies from your audio device go directly into your ear and are attenuated to almost the same degree as just wearing foam earplugs, like on the shooting range, etc. This allows you to perceive the audio without the background noise and allows you to turn the volumes down significantly, eliminating distortion and actually being able to enjoy the audio. Once you get the hang of using these and keeping the cords from snagging on your belts or chin strap, they are fantastic in my opinion. True racers know this and they have access to all the best equipment. We can too, for a fraction of the cost of custom molds. Now for the reveal:
www.cep-usa.com
The actual part number is CEP 508-SR
The advantage to these is the quality cabling and the quality transducers. They are the only company I found that uses “COMPLY” eartips, same as the military. They simply thread on with a quick twist and last longer than any other product I’ve ever used. It has a standard 3.5mm stereo jack on the end and the cable length is more appropriate (shorter) than standard earbuds, making it easier to get them out of the way to prevent snagging.
Now the downside, because everything has a downside. First, their website is like something from the 80’s. Terrible. You seriously have to call to order them. Second is price. These run about $100.00 shipped with a sample of tips. Once you try them and figure out the size that fits you best, you can order the replacements from them or they are available in several other places online.
OK, now that we discussed the benefits of earbuds vs helmet speakers, you can save a few bucks when you order the helmet kit as Rugged sells just the mic boom with a 3.5mm female stereo jack. I believe PCI does as well. I have found using the Rugged helmet mount works very well for the install and I even went so far as to drill and tap a small hole in the mount and used a clamp to secure the jack where you can easily feel for it with the helmet on and it won’t just flap around. All in all, a nice clean installation that works very well and is comfortable to use for even the longest rides.
I hope you found this informative.
