SKU: 447074
PM or order online:
DESCRIPTION:
Our team spent copious amounts of time at the R&D table with this kit, our end result was creating a light kit that will give you the performance and style your Can-Am X3 deserves. With the low amperage draw of the six S1 lights this kit won't draw a substantial amount over the stock lights though will greatly improve your driving experience. With our plug and play wiring system and precision cut and bent brackets installation is a breeze. If you're looking for lights that will set your X3 apart from the crowd and also give you race quality lighting this is the kit for you!
Includes:
PM or order online:
Can-Am X3 Headlight Kits by Baja Designs
Specifications: Lumens: 14,250 Utilizing 6 LED Wattage/Amps: 120W / 8.7A LED Life Expectancy: 49,930 Hours Front Lens: Hard Coated Polycarbonate Housing: Hard Anodized & Powder Coated Cast Aluminum Hardware & Bracket Material: Stainless Steel Exceeds MIL-STD810G (Mil-Spec Testing) Built-In...
www.proutvparts.com
DESCRIPTION:
Baja Designs Features: Satisfactions Guarantee – 30 Day Money Back Guarantee Limited Lifetime Warranty – Complete Purchase Protection uService® – Replaceable Lenses And Optics ClearView® – All The Light, Right Where You Need It. MoistureBlock™ – Waterproof, Rain Proof, Submersible CopperDrive® – Only LED Driven At 100% 5000K Daylight – Less Driver Fatigue, Natural Color | Specifications: Lumens: 14,250 Utilizing 6 LED Wattage/Amps: 120W / 8.7A LED Life Expectancy: 49,930 Hours Front Lens: Hard Coated Polycarbonate Housing: Hard Anodized & Powder Coated Cast Aluminum Hardware & Bracket Material: Stainless Steel Exceeds MIL-STD810G (Mil-Spec Testing) Built-In Overvoltage Protection IP69K (Waterproof up to 9ft & Pressure Washable) IK10 Compliant (Mechanical Impact Testing) |
Includes:
- x4 S1, Spot LED Lights
- X2 S1, Wide Cornering LED Lights
- Headlight Brackets and Fascia
- Plug & Play Wiring Harness
