Hi, I need to grease the bearings in the next few days. I have a 400lbs battery powered impact wrench. Will it be enough to brake the axle nuts loose on the X3?
TIA
TIA
175-185lbs when I put it back together?Double what’s needed ......do you know the axle nut torque ?
Sigh.. I'm glad it came off but I've long lost patience for underpowered tools. 1/2" milwaukee impact doesn't even struggle to pull axle nuts off on the most seized up ones there are lol. At some point you get tired of fooling around and just buy the big guns for projects like this. It'll save you a lot of time and trouble in the long run even if expensive initiallyIt worked. Approx 30 seconds per axle nut before it broke them loose (and nearly 2 batteries). Thanks for the input.
Yes, good point. For me personally greasing the bearings, suspension and changing the oil, brake pads and such is the most my mechanical skills will allow me to do. Anything more than that and it would go to the dealer for service. So my own tools and power tools reflect that. Not going to invest in tools I won't use.Sigh.. I'm glad it came off but I've long lost patience for underpowered tools. 1/2" milwaukee impact doesn't even struggle to pull axle nuts off on the most seized up ones there are lol. At some point you get tired of fooling around and just buy the big guns for projects like this. It'll save you a lot of time and trouble in the long run even if expensive initially
that sounds like you get 15 seconds per battery !It worked. Approx 30 seconds per axle nut before it broke them loose (and nearly 2 batteries). Thanks for the input.
I agree, my milwaukee impact is one of the best things i bought, worth the very many penniesSigh.. I'm glad it came off but I've long lost patience for underpowered tools. 1/2" milwaukee impact doesn't even struggle to pull axle nuts off on the most seized up ones there are lol. At some point you get tired of fooling around and just buy the big guns for projects like this. It'll save you a lot of time and trouble in the long run even if expensive initially
