1 - 1 of 1 Posts
The Assault Industries Adventure Rack X (ARX) offers excellent utility and increased storage capacity for Can Am Maverick X3. The shallow bed on the X3 makes it difficult to carry much cargo along with you on the trail! While riding anything can happen and having a place to store tools and a spare tire are invaluable!
The ARX is made from high grade mandrel bent steel, welded and finished with a textured powder coat. Since dirty tires will be mounted to it, the finish is more rugged than standard smooth powder coat.
Ultra heavy duty side mounts support the rack with rear pivots and front strikers. The entire unit is self-contained and should require no cutting or drilling to install. The mounts install into the vehicle using existing bolt holes on rear of the cage and inside the bed. Designing the mounts this way allows the user to easily remove the rack without leaving unsightly cuts and drill holes.
Heim bearings on the rear pivots and EZ lift gas shocks make for ultra smooth operation. The Strikers are integrated into the mount brackets while the latches are mounted to the rack itself.
Bed clearance from the highest point in the bed to the bottom of the rack is 8.25" or 209.5mm
Check it out HERE and use discount code MAVF2020 at checkout!
266699
266700
1 - 1 of 1 Posts
