I've noticed two different types of rear window nets one being a finer mesh and one being a larger, I'm assuming both stop the whirlwind effect from in the cab. But does one prevent more dust than the other or are they just about the same?
x 2!the mesh is better at stoping dust and wind. Also is a great shade.
X2^^IMO nothing beats the clear window for $99
Dragging up an old thread. Cholber1 do you have a picture of how this is holding up? I need a rear window, like the clear can-am the best but unsure of the durability.Im sure it would. I have the clear plastic window with harnesses. I just slotted them. Worked perfect.
X2A lot of it depends on whether you have a full windshield or not. If you don't and don't plan on getting one to can run either net style your choice. But if you are going to run a full windshield with a roof then to stop the dust from coming in cab you will need a clear plastic window or I would go with the mesh screen not the net.
