1 - 15 of 15 Posts
· Official Site Vendor
Start a conversation or order online:
Alba Racing's "Baja Crusher" wheels are made from Heat Treated 6061-T6 Spun Aluminum. They feature billet CNC machined 6061-T6 rings, flanges and centers. These are the strongest wheels on the UTV market. Cast wheels will typically crack or "Shatter" on impact due to cast metals being brittle and porous from the manufacturing process. Our wheels are drastically stronger than a cast wheel but if you do experience a sharp high speed impact they will bend and at least not shatter like a cast wheels. They also typically still hold air if bent letting you get home and not leaving you stranded on the trail! This is the reason racers prefer a non-cast wheel. Our bead-lock rings and receivers are the toughest as well as thickest in the industry at 3/8" thick each! Even with all the added material thickness and strength these wheels are still lighter than most cast wheels!
Contact us for custom Colors 801 367 1395
Features:
-Hand built and designed to your specs. Make it yours.
-Fully Serviceable (This is a True 3 Piece Wheel)
-Heavy duty 3/8" thick billet 6061-T6 CNC Bead Lock Ring.
-Heavy duty 3/8" thick billet 6061-T6 CNC Bead lock Ring Receiver.
-Oversized 8mm Grade 8 Bead Lock Bolts.
-.200" 6061-T6 aluminum heat treated inner and outer halves.
-.600" thick 6061-T6 billet CNC center.
-Built tough yet still lighter than most cast wheels.
-Extremely durable Heat Treated 6061 Aluminum.
-Rolled inner lip for extra strength.
-Powder coated black with your choice of ring color.
Includes: (sold each) If you need 4 wheels buy 4.
-Beadlock wheel.
-Beadlock ring your choice of color.
-Grade 8 beadlock ring hardware.
-valve stems.
Easy Tire Mounting - Can be done in your garage
The color you receive is the color in the picture
Warrantied for manufacturing defects for 6 months
Beadlock ring TORQUE SPECS: 18-20 Ft lbs
DESCRIPTION
About customization: A beautiful set of wheels is the biggest thing you can do to your car to make it stand out and look incredible.
NC finish: After the Beadlock Rings and Centers are powder-coated we then re-mount it to the CNC and re machine the edges and pockets. See the picture.
Wheel Weights- 15x7 = 17LBS, 15x10 = 19LBS, 14x7 = 15LBS, 14x10 = 16.5LBS
PM for your deal or Order Online:
265639
1 - 15 of 15 Posts
